Sponsored by: CARiD
knocking when I turn......
Old Jun 22, 2010 | 04:59 PM
cheetoe22's Avatar
I have a 2008 F150 fx4 5.4 with a six inch bds lift 20" wheels and 35" tires, I just started to hear a knocking coming from the drivers side when I turn right any idea where I should start looking?
Old Jun 22, 2010 | 06:47 PM
papajohn's Avatar
turn at full lock or partial turn?? also are all you lugnuts tight? loose lugs can cause a wheel to shift a lil bit back and forth.
Old Jun 22, 2010 | 06:48 PM
thejake1989's Avatar
sure your tires arent rubbing?
Old Jun 22, 2010 | 09:40 PM
cheetoe22's Avatar
Just a normal turn not full lock, and only when I turn to the right.
Old Jun 22, 2010 | 09:42 PM
cheetoe22's Avatar
No not rubbing its a knocking sound I have trimed everything is sight
Old Jun 22, 2010 | 09:45 PM
cheetoe22's Avatar
Ill have to check my lugs it just started when I got my truck out of the shop for a master cylinder replacement. Dont know if it has anything to do with it.
papajohn's Avatar
can you have someone stand outside the truck while you make your turn in the park lot to see if that person can pinpoint an area the noise is coming from in the truck??
Old Jun 22, 2010 | 10:01 PM
cheetoe22's Avatar
Yea already did that, cant hear anything. Only happens when Im driving.
Old Jun 23, 2010 | 12:50 PM
Keeks's Avatar
Did they replace brake pads as well? If so, you could have a loose caliper. My truck did the same thing you described when one of my calipers was not tighted properly... Just an idea
Old Jun 24, 2010 | 06:25 PM
Diggler's Avatar
CV shaft maybe?
Old Jun 25, 2010 | 11:33 AM
Shooter-MMA's Avatar
Also wouldn't be a bad idea (if you have not already) to get your torque specs back out and go over all the BDS installed parts from the lift install.
Old Jun 26, 2010 | 07:43 PM
cheetoe22's Avatar
Bingo that was the solution!!! Thanks!
