Leaf spring replacement...good idea?
I was looking at towing more or towing with out the rear end dropping. I know you got helper springs and airbags but with a new leaf kit would it work just as good and not have to be filled with air when ever I have a load? Im not really worried about ride quality being affected. The lits I was looking at are rated up to 2400 lbs. And I think the stock FX4 springs are rated at 1200 lbs(correct me if Im wrong). So for the money would it be worth it or is there a better route? Here a link for some Im looking at!
http://thesuspensionking.com/catalog...ibvbquucoi25c1
Last edited by onefast96svt; Jun 6, 2010 at 09:18 AM. Reason: Changed mind on header
When you use the term "spring rating", are you referring to the amount of weight it takes to compress the leaf spring 1 inch? I'm not sure if that is what "spring rating" is but I seem to remember reading something like that somewhere before. If that is the case, you would be paying $200 to double your spring rating. So it would take double the weight to compress the new HD spring 1 inch. If your goal is to keep the rear end from sagging with a load, look at it this way. Using your numbers, with 4800 lbs of load, stock FX4 springs would sag 4", the new heavy duty ones you linked would only sag 2". For $250 you can get air bags, such as the Firestone Ride Rites, that add up to 5,000 lbs of weight carrying capacity, so at that same 4800 lbs, your truck wouldn't sag at all. The air bags are easier to install, plus, if/when you get rid of your truck, you simply unbolt the air bags and you have a stock truck which appeals to more buyers. Then, you also have the air bags to sell here in the classifieds. Just some ideas for ya!
Just be mindfull of your trucks weight carrying capacities as 5,000 lbs is probably over the recommended limits.
OK so adding a set of air bags like your saying I could put 5k lbs in my bed? Im not really looking to max outthe truck but when I do carry things it sucks to be looking up the whole time. Like last week about 15 sheets of plywood, 6 4x4, 2 4x6 and a few more odds items and it was sitting a little low, not to bad but some. I want it ride level when I carry most things like that. So if airbags are the way to go I guess get those.
And NO, I am not saying you can put 5,000 lbs in the bed of your F-150. As I stated, pay attention to your trucks weight carrying capacities. What I am saying is the air bags will let carry up to that capacity without sagging the rear end.
