Help pick what leveling Kit PLEASE!
I have a 2008 F-150 FX4 and I want a leveling kit thats bigger than 2.5 that also has the rear shocks or absorders or w/e haha. I dont know what brand to go with of which one will look the best please give me some suggestions and pictures if you have any.
You dont want to go anything over 2.5 inches trust me. You will put way too much stress on your ball joints, tie rods, and etc. Just go with a 2.5 and either aal or blocks for the rear if you need them. If you really want to upgrade shocks then go with bilsteins. They will give you a better ride. Also Autospring seems to be a good product around here. Ive had mine for over 3 yrs and no problems yet with it.
on you will be fine, on my old 05 i put a leveling kit on at 70,000 miles then at 90,000 miles i put a full suspension lift. Just maybe check your ball joints when you have the truck apart
Ok, I am also thinking of doing this. However, I have a related question.
I'm clear: no more than 2.5" leveling kit in the front. AND run a add-a-leaf or spring-block in the rear.
To be honest, I'd probably go the Bilstein or Rancho route for the leveling shocks.
HOWEVER, here is my question:
When adding a leaf to the rear, or when adding a spring-block to the rear, do we ALSO change out the rear shocks to adjust for the new length of travel?
