Sponsored by: CARiD
replace ball joints
Old May 24, 2010 | 11:32 AM
brooklynjim's Avatar
replace ball joints
How hard is it to replace BJ on a 99 f-150. I'm handy and don't mind getting dirty. Any tips. Thanks
Old May 24, 2010 | 11:40 AM
(if you are doing lower BJ) rent a ball joint press from Autozone or your local parts store
have a 2lb or heavier hammer for breaking the BJ from the spindle/knuckle
have a prybar atleast 30" to aid in breaking the BJ from the spindle/knuckle
use a pail or something to hold the spindle/knuckle up when you take the BJs loose
Old May 24, 2010 | 11:26 PM
fordracing200's Avatar
its easy, just buy a balljoint press from tooldiscounter.com unless you never plan on doing them again then you can always rent it, but heres the how-to....figure 6-8hrs if your a first timer....mostly a day job.
http://www.ford-trucks.com/article/i...ll_Joints.html
Old May 24, 2010 | 11:28 PM
i used a pickel fork and hammer to get the lower ball joint broke loose, the uppers I had already replaced previously so I just whacked the control arm with a hammer and they popped right off.
