Sponsored by: CARiD
1.5" Level on a 2WD
Old May 13, 2010 | 09:03 AM
Lariat-Rules's Avatar
1.5" Level on a 2WD
Is this something that you guys would mess with? what is the advantage of buying this and installing it. Found one for 50 bucks used and wondering if i should buy or pass.
thanks
Old May 13, 2010 | 11:54 AM
ucfperspicere's Avatar
"Advantage" is just a more level-looking stance. A little more front clearance if that's important to you. Will make oil changes slightly easier without jacking... But mainly aesthetics.
Edit: Make sure you take into account the $60 a new alignment will cost. And I'm assuming you're talking about a front leveling kit, not a rear level/drop.
Old May 13, 2010 | 04:48 PM
Almost forgot the other "big deal" of adding a leveling kit: You can put on slightly larger tires without having to do a full lift, if you're into that.
(remembered this after looking at some posts in the Wheels, Tires & Brakes section)
Old May 17, 2010 | 10:03 AM
Thanks for the tips..
i think i may look into the rear drop shackles if thats what it is called, i heard that it will make the truck look better..
Old May 17, 2010 | 11:27 AM
On a 2WD, the rear 1.5" drop will level it out with a sportier stance. I plan on doing this mod myself when I get some big wheels.
