Sponsored by: CARiD
Tcase and diff fluid
Old May 2, 2010 | 08:37 PM
wreedKR's Avatar
How do I change the tcase and diff fluids in my 07
Old May 2, 2010 | 08:40 PM
mhockey9090's Avatar
Did you try searching it on here?
Old May 2, 2010 | 08:41 PM
wreedKR's Avatar
Well I know how to do rear diff, I just need to figure out Tcase and Front diff.
Old May 2, 2010 | 09:39 PM
feyded1020's Avatar
The Transfer case has a fill plug(and drain plug) on the back end of it facing the rear differential, take a ratchet to it(forget the size the plug is) and drain it, then refill with the correct fluids(I used Amsoil ATF).
The Front differential has a fill plug on the top of it facing the rear differential, but as for a drain Im not sure as I took off the front of the pumpkin to drain mine.
Hope that kind of helps =/
Old May 2, 2010 | 09:46 PM
wreedKR's Avatar
That helps with the tcase. Anyone use a pump to pump the fluid out of the front and rear diffs?
Old May 31, 2010 | 06:35 PM
wreedKR's Avatar
How do yall get the fluid in the tcase? I looked at it today and it did not seem like there was enough room to use a funnel.
Old May 31, 2010 | 07:44 PM
papajohn's Avatar
you just get a small special cap that screws on the end of the bottle that has a small point on it. cut off the tip, jam the tip into the hole, then squeeze the bottle empty into the fill hole.
wreedKR's Avatar
I can get one at auto parts store?
