36,000 miles lower ball joints?
Went to have a front end alignment done and the mechanic said I needed lower ball joints. I just bought some new tires and had someone mount them for me that did not have an alignment machine. I took it to this shop just for the alignment. I figured they balked at the alignment because I didn't buy the tires from them and wasn't going to make any money with just an alignment. The truck is a 2005 f150 XLT 4x4 with only 36,000 miles and all stock. Is it likely I need new ball joints with such few miles?
It's not uncommon. The ball joints wear out quickly on all the 97-08 F-150's. Mine lasted about 56,000 and my truck is babied. However, I was running larger tires on wide wheels which increased the wear. If you are running a larger tire and/or wheel they may well be worn out.
just check em your self. Throw a jack under your lower control arm to load the ball joint then put a pry bar under the tire and pry up and watch to see if the ball joint moves or if theres any play in your tire up or down
