Sponsored by: CARiD
uca help
Old Apr 26, 2010 | 03:17 PM
mav015's Avatar
uca help
hey yall trying to install camburg ucas
cant get the stock uppers out the bolt that goes into the spindle wont come out got the nuts and all the other bolts off just cant ge this one out
any tips to get it out?
thanks yall
Old Apr 26, 2010 | 05:21 PM
FlashmasterK's Avatar
Big f'ing mallet. Bang on it and then bang some more. Drink a beer while banging on it. Have your g/f or wife make you a sandwich and feed it to you while banging on it. Eventually it will give way.
Old Apr 26, 2010 | 06:22 PM
sbchris's Avatar
Get a sledge hammer, 3-5 pound, and hit the top of the spindle from the side. Don't beat on the bolt or the uca. Hit it good and hard.
Old Apr 26, 2010 | 06:29 PM
mav015's Avatar
ok wat if i have hit the uca and the bolt a few times?
Old Apr 26, 2010 | 08:17 PM
l337viton's Avatar
You might want to put the nut back on the bolt while you hit it with the hammer so that when the spindle/knuckle finally drops out it doesn't just drop on you. Obviously not completely tight, a few turns should do it.
Old Apr 26, 2010 | 10:01 PM
sbchris's Avatar
Nothing, just the correct way to get the bolt loose is to hit the spindle according to the instructions in all the lift kit install guides. I'm sure you can deform the bolt though hitting it hard enough.
Old Apr 27, 2010 | 12:36 AM
mav015's Avatar
thanks yall
Old Apr 27, 2010 | 02:50 PM
mav015's Avatar
got it out today alittle heat and a big slug hammer it came right out
thanks for the help yall
