Tire cupping inner and outer edges
2001 Excursion, 5.4L, Rear Wheel Drive - Can poor shocks cause tire cupping only on inner and outer edges of tires (all 4 tires). Center of tires looks great. I have the tires rotated every 5K miles and have the alignment checked every 10K miles and toe adjusted if necessary. Caster and camber are always in specs. Put new shocks on vehicle when tires had about 40K miles on them. Noticed cupping at about 60 K miles. Had to replace tires at 90K miles because of cupping and noise. Replaced the shocks (same brand) when I replaced the tires. However, I am concerned about the possibility of the new tires cupping The old tires had enough good tread in the center of the tires to go at least 150K miles if the edges had not cupped. Please advise, I don't want to repeat with the new tires Thanks!
sounds like an alignment issue to me... I would have that checked, most places will do it for free. Poor shocks will typically cause flat spots all the way across the tire. //// from hopping. could also be loose/worn ball joints.
It sounds like you've covered your bases on shocks and alignment. It's pretty unlikely that shocks would cause uneven wear on both edges. This sounds more like an underinflation issue than anything since it does it on the rear as well as the front. What kind of pressure do you run in the tires?
It sounds like you've covered your bases on shocks and alignment. It's pretty unlikely that shocks would cause uneven wear on both edges. This sounds more like an under-inflation issue than anything since it does it on the rear as well as the front. What kind of pressure do you run in the tires?
I'd say you're good to go. Just keep an eye on your tires, especially the fronts and make sure they're wearing evenly. If you notice the outer edges wearing excessively front I'd bump them up to 50 or 55 as well.
I'm not surprised the Firestones wore well for you, those were some of the best tires I've ever seen for treadlife regardless of pressure. Did you happen to get Perelli Scorpions out of the Firestone recall? If so, I'm also not surprised you had wear issues with those.
