Add-A-Left and Air Bags
Right now i have a 2.5 leveling kit on the front. Im looking to raise it a little more. Anyone have the set up of an AAL and Airbags? Or any other suggestions on lifts. Suspensions are nice but I havent been able to find a good deal on one yet.
If you're looking for a little more lift the add-a-leaf is prob. the cheapest solution next to adding a bigger block. An airbag kit like the firestone or Air-Ride usually run around 200 bucks. I installed the air-ride on my truck just because I like the idea of being able to inflate the bags for when i tow our trailer, this way the back end doesn't start sagging and stays level. A add-a-leaf also acomplishes this as well. If you do go with a new leaf. try and get a Long add-a-leaf, they are supposed to not ride as harsh as a short add-a-leaf.
FYI i can get about 1"-1.5" of lift if I inflate my airbags to about 20psi or so. Add-a-leafs usually are around 2" i believe.
That's about what I get out of my Ride Rite bags at 20 psi, but, they go up to 100psi! I have never measured but it probably raises the back 4" +/- at 100 psi. I like the bags cause you can deflate them enough to just maintain your desired lift height when unloaded for a close to factory ride. With the AAL, what you get is what you get. Plus, the bags are much easier to install.
I agree! I've had AAL pain in a$$ to install rough ride! I now have air ride air bags 1 hour to install, I also tow trailer daily. You can get a lift block for the air bags, they come in 2";4" and 6". I used blocks from body lift + longer bolts!
I don't want to hijack this thread, but I didnt want to start another post. I have a leveled fx4 and a 3in block right now with 35's. Im looking to raise the rear a little more, but also need a little more support when towing my tri-jetski trailer and occasionally a friends boat. Should I go with AAL or airbags? my concern is that I never tow during the winter and I don't want poor ride quality.
Also, if I were to get airbags, any suggestions on a brand and place to get a good deal on them?
+1, Nice catch...it mush be from the fuel tank and the driver all being on one side
Add-a-Leaf...that my friend is something different.
http://www.summitracing.com/parts/FI...n/?prefilter=1
or this place for a buck more
http://www.suspensionconnection.com/...scon/2350.html
Thanks everyone, I think im going to go with the air bags. Now I have a 2 in leveling kit in the front. So my truck is level, so this means ill need air bags for the front and back. Does anyone have any good brands theyd recomend?
Will the firestone rite-ride kit 2320 work with the fabtech 6' lift? If the rear springs are wearing out, would it be a better choice to install new ones or install the air bags to control rear end sag while towing/hauling. I have priced new springs at $400 while the air bags are $210.
01 F150 Screw 4x4
fabtech 6" w/35" procomp all terrains
01 F150 Screw 4x4
