Sponsored by: CARiD
is anyone using Super Lift traction bars???
Old Mar 19, 2010 | 03:31 PM
Veteran: Army
I'm just wondering if anyone is or knows of anyone running "super lift" brand "supertrac" traction bars
here's a link where I found them
Originally Posted by rocky mountain suspesion
Super-trac™ Traction Bars by Superlift can withstand the tremendous torque loads generated by high output engines and large tires. With Superlift's design, the bars' rear-end attaching points are incorporated into replacement U-bolt plates. To further enhance strength and rigidity, the traction rod eyes are supported on both sides. Front mounting brackets feature a slotted hole which enables you to control the amount of rear suspension wrap-up and dial-in the desired degree of "launch". This prevents excessive wrap-up without restricting suspension travel. These are not compatible with contact overload springs.
these are the bars:
http://www.rockymountainsusp.com/ind...knumber=100+SL
they also require the purchase of the mounting brackets:
http://www.rockymountainsusp.com/ind...knumber=111+SL
I called superlift and the reason they are advertised for 4X4 use only is because they have not been tested or mounted by Super Lift on a 2 wheel drive truck
Old Mar 21, 2010 | 04:06 PM
Veteran: Army
no one????
has anyone heard anything about these???
