Sponsored by: CARiD
spueaking when i turn
Old Mar 14, 2010 | 11:43 PM
kawi08's Avatar
have a 97 f150 4x4. ive replaced upper a-arms, bottom ball joints, and cv joints. every time i touch the steering wheel i have this horrible squeak. could it be a pitman arm? ive greased everything underneath the truck and the tie rods are good. thanks for any advice. jeff
Old Mar 15, 2010 | 09:39 PM
jdrozdow's Avatar
Based on all of the items you have already replaced. If the noise is still outside he truck then it has to be a steering linkage joint. The idler arm may be the bad guy. If the noise isn't coming from outside (sometimes hard to tell) look at your steering column, dash boot/seal and I/shaft.
Good luck!
Old Mar 16, 2010 | 05:43 PM
97f1504x4jim's Avatar
I had a squealing when i first bought my truck and all i did was buy some rust check and this stuff thats like a liquid grease and sprayed all my bushings and and anywhere that moved and did not have a grease nipple and i have gone 35,000kms without a squeal
Old Mar 19, 2010 | 02:55 PM
wcperryman's Avatar
Little bit of a bump, but.
I had the problem but only when turning left.
Turned out to be wheel bearings.
Something to think about.
Old Mar 19, 2010 | 03:33 PM
hunterjh's Avatar
i had the exact same problem...it was my IDLER ARM and the squeak was awful...cost me $150 bucks at the mechanics
