New front end work done. Confused..
I had a 2 inch AS level on my truck and it made the front about half inch higher then the rear. So I got a 1.5 inch AS level. While I was at it I got some new bilstein shocks for the front aswell. Had everything installed today. Now The front still sits at about the same height as it did before.
Even with the smaller level. Whats going on? Is it the shocks? Do they need to be "broken in" per se and the truck will eventually settle in lower?
Rob
The Bilsteins are a gas pressurized shock. The old shocks were probably worn out a bit (probably easily compressed by hand) so you end up with a tiny bit of extra height. The may/probably will settle down a bit with a few miles.
Thanks for the replies. Around how many miles do you think it'll take for them to really settle in? Think it'll settle a half inch or so?
Throw some add a leafs in the back.. they add close to an inch. Truck can use and extra leaf anyways... I don't tow anything, bought from the original owner who never did either and 8 60lb bags of concrete int he back had her squatting lol.
