Sponsored by: CARiD
What is this?
Old Feb 25, 2010 | 08:57 PM
kwfireman10's Avatar
What is this?
i just installed a 2" drop shackle on my 2008 FX2 super crew, the rear driver side frame above and to the inside of the the shackle has a small black weight looking thing that seems to be sitting on rubber gromets on the frame rail, What is that and is it important to keep?
its in this pic behind the shackle
https://www.f150online.com/forums/me...op-shackle.jpg
Old Feb 25, 2010 | 09:29 PM
I think it's supposed to be some sort of vibration suppressant.
Old Feb 25, 2010 | 09:54 PM
in order to get the bolt out of the old shackle i had to lift it over the frame rail, that was in the way so i cut the front bolt and i left the back one in just incase it was something important. What should i do? take it out completly?
Old Feb 25, 2010 | 11:20 PM
you can try taking it out, but if you end up with a vibration just put it back in. If it were me i would probably just leave it alone.
Old Feb 27, 2010 | 07:11 AM
i only cut one of the bolts off so right now its just hanging there by the other bolt. im going to try and secure back on somehow.
Old Feb 27, 2010 | 08:59 AM
gotshot's Avatar
Yes it is a vibration dampener. Right after I bought my truck I noticed the bed shaking so they installed that to try to fix it. I don't think they come stock at least on my 05. It worked a little bit no ride difference just didn't look so bad in my mirror.
Old Feb 28, 2010 | 02:49 PM
it dosent touch the bed though, it just sits on the frame rail on 2 rubber gromets.
Old Feb 28, 2010 | 06:42 PM
leftlane kid's Avatar
my 05 stx had one and when i took it off it shook like #### i would take it off only to work on things then put it back on i installed a tow hitch on mine
when u hit a bump it takes the vibration out of the frame caused by the suspension
Old Feb 28, 2010 | 10:38 PM
how did u attach it back to your truck?
