Sponsored by: CARiD
Monroe Reflex shock?
Old Feb 8, 2010 | 11:56 PM
Rush0212's Avatar
Got a question I think I know the answer for , but need to ask you pros.
Recently bought a set of Reflex shocks and had them installed.
Since the day I got it, the ride is awesome, but the shocks make almost non stop noise, knocking , pinging etc.
This cant be normal at all. Any ideas of what it could be, before I bring it back and say and say WTF???
Old Feb 9, 2010 | 04:02 PM
beechkid's Avatar
25 Year Member
Junk and here is my recommendations for replacement;
Shock Recommendations IMHO:
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street (such as Bridgstone that are 100% steel belted or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG that are a mix of steel & nylon belted or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The GR-2’s are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.. Best shock for the $/best price typically found at Performance Suspension Technologies (PST) and typically about 1/3 less than Bilstein.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
