2 inch lift
not doing a body lift cuz iv got a brushguard already on it. wuts the best way to go with the lift then. torsion keys and blocks with new shocks or do they have add-a-leafs for it. looking for a good ride with just a lil lift
Aftermarket torsion bar adjustment keys have to be the worst product ever made. THey allow you to put way, way too much preload on your torsion bars which will increase wear and tear on your front end and destroy your ride quality. Just crank up your torsion bars with the OEM keys.
thanks for the help. thinking about maybe going to a four inch. do you know any good ones that aren't crazy expensive?
is a great option because it comes complete. You get brake lines in it, for example.
Stay away from A arm bracket kits. They are hard to keep aligned and you will spend more in tires down the road.
It's going to be hard to get all that for a grand. If that's your budget you should do a 3" body lift and gap guards. Keep the factory ride.
If all you want is 4" that might be a good choice. It says you can get 35" on it, but I doubt you could do that without a lot of trimming. Also, I would upgrade to the gas shocks, which are standard in a higher quality kit.
Any lift bigger than 4" should come with lateral compression struts, the long ones from the rear cross member to the frame.
http://www.ntwonline.com/97-03_F150_...P12745C788.cfm
Is the RCD 5" kit with Bilstein 5100 Shocks, not bad for $999.99
http://www.racecardynamics.com/produ...4wd150full.htm
