Trying to fit 35's w/ 2wd
Whats up guys, I have the HBS 2.5in leveling kit on my 05 2wd f150 and as of right now I have 33's, and we all know once you do a little lift you just want to go higher and higher...
So my issue is how do I fit 35's with out buying a lift kit? I'm also contemplating getting king shocks if that will help with the clearance?
Should i get a bigger block for the front and then add-a-leaf in the back?
Thanks for the help
Thanks for the help
i agree with wandell, get a 3" P.A. body lift from amazon, they only cost $180 and you will clear 35's with no problems.
your other option would be to get a 3" spindle lift and then get a 3" block for the back or AAL.
You can clear aftermarket wheels fine. With 6"of lift(how much you will need to run 35s) I would recommend 4.5" of backspacing on them.
yeah but isn't a spindle lift just a larger spindle. there are plenty of companies that make 2wd lift kits with drop down brackets and all but the op was asking about spindle lifts.
I knew I was going crazy i have been looking for those spindles for probably 2 days online now wow haha....so from here where would u guys go if you were on a budget of lets say 1000 not including wheels and tires.
