Sponsored by: CARiD
RIZE King Coilover Problems
Old Dec 5, 2009 | 04:17 PM
gp1300r110's Avatar
I've got an 05 screw with 8" Rize. Put King Piggybacks in the rear, and king coil overs in the front. I have tried and tried and tried some more to crank the coilovers to gain more lift. The problem is that they just will not budge. So today I took the whole thing out of the truck to compress the spring, and I notice that the adjuster collar is cross threaded on the shock shaft. Has anyone heard of this happening?? I have exhausted all of my ideas, and have no idea what to do about it???
Old Dec 5, 2009 | 04:39 PM
4.2trimble's Avatar
wouldnt that be a manufacturer default. Maybe its time to see this warranty that everyone talks about from KING.
Just my opinion
Old Dec 5, 2009 | 05:03 PM
gp1300r110's Avatar
I wish it was that easy. I bought these second hand, so i have no idea how the warranty system works. I doubt they would be covered
Old Dec 5, 2009 | 05:11 PM
sbchris's Avatar
Could be one of three things
Could the be the aluminum adjuster nut is crossed up on the steel threads of shock body
Could be a defect in the steel thread on the shock body itself
Or it could also be from the aluminum nut that holds the steel locking stud. If the stud is tight/or was tight and was turned, you can imagine what the threads would look like. My guess would be a mess from steel on steel.
I'd try to back the aluminum nut all the way to the top and check out what the threads look like.
Old Dec 5, 2009 | 05:14 PM
gp1300r110's Avatar
Are you talking about the little allen key screw that pinches the collar tight? It was loose when we tried to crank em up. Now i cant move it all when i spin the adjusting collar, it spins the entire shock body instead
