Sponsored by: CARiD
Front end creeking
Old Nov 27, 2009 | 05:21 PM
njmike's Avatar
Front end creeking
Just got 5" RCD lift put on my 01 f150. Now there is a creeking noise when i turn the wheel hard or at slow speeds and when you come to a complete stop or hit the brakes hard at a slow speed. Does anyone know waht could be causing this?
Old Nov 30, 2009 | 04:40 PM
screw_firstdate's Avatar
Where does it sound like its coming from?
Old Nov 30, 2009 | 06:08 PM
njmike's Avatar
It sounds like its coming from the front driver side wheel area
Old Dec 1, 2009 | 10:20 AM
Can you lift the driver side tire off the ground and move it around? See if you can duplicate it...or at least see if its your ball joints. You may also want to double check your bolts from your install. Maybe something got twisted if you tightened one side down harder first. I know on my fabtech...I had to try and install the front axle like 3 times. It kept binding and twisting in the brackets.
