Ball joints and control arms
My 2000 F150 needs front end work. I'm reading the Haynes manual and it says " The balljoint is an integral part of the lower control arm and cannot be replaced separately.
You must replace the entire control arm.
It says the same for the upper ball joints and control arm.
I thought I could just replace the ball joints.
Am I reading all this correctly?
I think you can get the press from Autozone as well. You didn't say if you had 2 or 4WD?? I know for certain the lower on the 4WD can be replaced separately, but not the 2. Place the ball joint in the freezer overnight and then apply head to the control arm before installaion. Will ease your pain.
