Fabtech 5" liftblocks(pics)
hmmm.......what was the model number that you ordered? I think the spindles would be good since Ive already got a spacer. Adding lift coils would just add to the cost with having to get shocks too. and the spindles are about the same height as the stockers?
That's prob my fave color on those gens, you may not believe you have 'bad' axle wrap but I'd be willing to bet if you threw on a cheap set of traction bars or ditched the blocks for re-arched springs you would notice quite a difference on take off and bouncing through the potholes
rcd makes them also for our trucks.
looks good brad. i just need to get a set for my truck and be good but im currently working on my full power conversion and more blue leds
Yea, but RCDs are like $300 just for the bars. Then you pay $135 for the brackets. Same thing with all those other traction bars. The lakewood ones I would never buy. But the others are almost $500 dollars by the time you have them on the truck. I can get a 6" leaf pack from Deaver for $700 and get the same effect with a better ride.
Thanks alot though. Hopefully you get it all figured out, and I need to do the LED thing big time. I hate all the green stuff.
i just put my order into superbrightleds for a couple new ones for the dash and 3mm ones for the switches so i can get all those done. once i do them all ill happily help you out with all your led lighting needs brad. haha. you just have to hook me up with some of those ones so i can do the air vent ones too
Every traction bar does the same thing. Lakewood's are used on many peoples trucks. Its a truck, it may not look preety but if it gets the job done thats all that matters. Lakewood's will work just as good as any other bar.
