Sponsored by: CARiD
best lift spindle?
Old Nov 19, 2009 | 12:50 PM
01f1502wd's Avatar
best lift spindle?
I have seen a lot of spindles out there, what would be the best one? Im also going for the cheapest of best quality.
heres some on just an easy google search:
http://images.google.com/imgres?imgu...%3D20%26um%3D1
http://www.doetsch-shocks.com/9.asp
http://app.infopia.com/Shop/Control/...ds_per_page/96
Old Nov 19, 2009 | 09:56 PM
wandell's Avatar
Doetsch are probably you best bet.
Old Nov 19, 2009 | 10:04 PM
01f1502wd's Avatar
are they pretty easy to install? just take everything off and put it back on?
Old Nov 19, 2009 | 11:04 PM
DeWayne24's Avatar
Hope someone will chime in I'm wondering the same thing here I'm tired of running down hill.. lol
Old Nov 19, 2009 | 11:08 PM
b2therad's Avatar
I just had a lift thread not too long ago talking about these. They are super easy to put on. You take the wheels and brake calipers off and set them to the side. Remove the spindles by loosening and then knocking the ball joints and tie rods loose. Then you put the lift spindle on and then see how the turn radius is because you usually have to take about an eighth inch off of the lip on the lower control arm. Grind away until it turns smooth in both directions, and bolt it back up. Install the rotors on the lift spindles and put the calipers back on. Put your wheels back on.. lower it down,tighten your lugs up and your done.
