Sponsored by: CARiD
What size of stock rear blcok on 4x4s usually?
Old Nov 16, 2009 | 03:58 PM
F_ast's Avatar
Hey guys, I have installed 2.5" leveling kits on both my 09 Fx4 and my dads 05 Fx4 and both are sitting nose high... expected at this stage. Orders myself an Add-a-leaf for my truck and a 3" block for dad. My question applys to the rears blocks. Crawled under my dads truck last night to find that his stock blocks are already 2"... From everything i have read, the stock rear blocks are 1-5/8". He does have the max tow on his truck; is this why?
I am a little confussed though. I measured the AS leveling kits at 1-5/8" and I know that is the 2.5" kit, but why did he gain so much? To level perfectly, he requires 1-1/4"as the truck sits now.
Just curious what size the 4x4, Fx4 and tow package blocks are usually.
Old Nov 16, 2009 | 04:17 PM
I had always heard that the 4x4s are 2" and he Fx2s are 1".
Old Nov 16, 2009 | 04:20 PM
Big_Smokey's Avatar
I thought they were 2 inch blocks? Im not a hundred percent sure though. I just know that most of the time with leveling kits to get the rear back up most people suggest a 3 inch block or AAL, so i assumed they were all 2 inch blocks on the 4 wheel drives. Im sure you knew that already. I also thought that the 04-05 trucks had more rake to start with, at least my 05 fx4 seemed like it sat higher then my 06 lariat.....
Old Nov 16, 2009 | 06:50 PM
Smokin Lariat's Avatar
I took mine off to lower my back end and 'level' the truck. They were 2"
Old Nov 17, 2009 | 07:11 AM
F_ast's Avatar
hmmm, not sure what i was thinking. I had 1-5/8" in my head for whatever reason.
Anyone know if there are 3-1/2" blocks available or if you can machine down a solid 4" block?
Old Nov 17, 2009 | 09:03 AM
Big_Smokey's Avatar
Im a little confused i guess...Ok so how much higher is yours sitting in the front...and how much higher is his sitting in the front...from ground to fender? dont look at what is under the truck ,because as you see from the leveling kits to get 2.5 inches its not a 2.5" spacer. I think its the geometry of the spacer and the strut that gives you that addtional length when you install the leveling kits. .Anyway, take some measurements on that first and see what you need for inches to make it sit level...If anything it would be better to sit with a touch of rake IMO. And im sure you can make your own adjustments to the blocks if its that much off. A half of an inch is pretty close to tell without a tape measure, but you gotta do what you gotta do!!
Old Nov 17, 2009 | 10:41 AM
F_ast's Avatar
Right, i know that a 2.5" leveling kits riser should actually measure 1-5/8". I understand it is geometry changes of the control arms that decrease spring pressure to help hold the truck up more.
I have not measured my truck in a while. But i did just measure his. He sits nose high about 1-1/4". He runs a 35" tire and his measurements where 40-3/4" rear, and 42" front. So if I were to add a 3" block, he would still sit slightly nose high about 1/4".
I will see him tonight and get back
Old Nov 17, 2009 | 11:08 AM
mhockey9090's Avatar
stock blocks in 4x4s are 2inch
Old Nov 17, 2009 | 11:15 AM
agreed, if you are trying to gain one inch over all, take the block out and do a 3" AAL
Old Nov 17, 2009 | 12:50 PM
Big_Smokey's Avatar
Thats a pretty good solution and you can add some extra load cap....Im actually in the same boat as you, because i added a 3" level to my 06..well it was supposed to be 2.5, but they installer put a 3 on so im bulldogging pretty good.. AAL is the way i will eventually go. It looks like to me the best thing to do for getting it perfect is buying a bigger block and "adjust" it to what you need.
Old Nov 23, 2009 | 08:42 AM
F_ast's Avatar
Update... 1-5/8" block on my 09 FX4 4x4
