moog tie rod end confirmation for 4WD
I need to replace the tie rod ends on my 05 4WD SCREW Lariat. I see some other manufacturers (besides Moog) have different tie rod end part numbers depending on whether the truck is 4WD or RWD. I only see the following listed for the 05 model with no designation on whether it is RWD or 4WD.
MOOG Part # ES3691
Frt Strg; Outer
MOOG Part # EV463
Frt Strg; Inner
I would just like to confirm these are correct for 4WD.
Thanks,
Matt
MOOG Part # ES3691
Frt Strg; Outer
MOOG Part # EV463
Frt Strg; Inner
Thanks,
Matt
I'm not sure but am a big fan of going to the parts houses and getting them there. This assuming you are ordering online, you could have had them bought paid for and installed with an alignment almost a month ago. I honestly don't see them using two different types of tie rods whether it be 4wd or 2wd so I'd say the MOOG part# is a valid one. I get Moog stuff from Carquest and am very happy with them, plus they are greaseable (very important)!
Yep, looks like the same tie-rod end for 2wd and 4wd vehicles and Rockauto.com confirms your part numbers. I buy all my stuff from them if I dont need something right away as they are the cheapest around. If you go there, you can use this coupon code to save another 10%: 21913471833097
Good luck!
Good luck!
