Sponsored by: CARiD
2wd ?
Old Sep 17, 2009 | 08:32 PM
Richhit's Avatar
2wd ?
Just wondering... Why can you put a rize 8 inch on a 2wd. Is it impossible?
Old Sep 17, 2009 | 10:28 PM
wandell's Avatar
I don't believe Rize makes a 4x2 lift.
Old Sep 17, 2009 | 11:12 PM
Richhit's Avatar
They dont. I was wondering what makes it not fit. Just wondering if it could be fabricated to fit. (or something)
Old Sep 17, 2009 | 11:13 PM
mixedbreed's Avatar
Why put that much into a 2wd? Just asking cause it seems to be more and more common
Old Sep 17, 2009 | 11:18 PM
Dnasty777's Avatar
Nothing wrong with a lifted 4x2. Really the only difference between a 4x4 and a 4x2 kit is that the spindles are different, the added hardware for the differential drop and maybe some other small stuff.
Old Sep 17, 2009 | 11:53 PM
Richhit's Avatar
because I have a friend that will give me the kit for real cheap. Its used for about a year. like 600 cheap
Old Sep 18, 2009 | 12:48 AM
mixedbreed's Avatar
So does a 2wd actually perform enough? One of the vegas guys has a lifted or leveled 2wd and although not my taste, it looks pretty cool.
Old Sep 18, 2009 | 08:01 AM
greencrew's Avatar
Bookmark.
Old Sep 18, 2009 | 08:03 AM
Neirti's Avatar
Ive mudded in my 2wd and it seems like it can keep up with some 4wd. I mean theres spots that i know i wouldnt take it but its also fun and more challenging especially if you have a lift on it. I have a 6"
Old Sep 18, 2009 | 10:38 AM
Richhit's Avatar
Ok I would do it for the look. Does anyone know if I could buy this off my friend and put it on my 2wd. It is a 4x4 kit.
Old Sep 18, 2009 | 12:30 PM
1BAF150's Avatar
IMO, no because the spindles arent the same as a 4x4..at least I'm pretty sure it wouldnt work, without the proper spindles.
Old Sep 18, 2009 | 06:25 PM
Richhit's Avatar
any one else know if I can do it?
Old Sep 18, 2009 | 08:07 PM
1BAF150's Avatar
Also, I wouldnt do it because I'm pretty sure the specs on the upper and lower control arms arent the same as a 4x2..theres more involved with a 4x4. That big Rize crossmember probably wouldnt fit the same...again, idk exactly but it's more than likely an unworthy cause..
Old Sep 19, 2009 | 08:18 AM
vegas08f150's Avatar
mine is a 2wd. if i want to go serious 4wheeling i'd just use my jeep that i built for that purpose. my truck does exactly what i want it to do that you cant do in a stock 2wd because of ground clearance. i wouldnt want to offroad in my 2008 f150 that i spent so much money on
Old Sep 19, 2009 | 10:58 AM
wandell's Avatar
Maybe research and compare the 4x4 vs. 4x2 lifts made by Pro Comp and Fabtech. See if the part numbers are the same for the components in the kits. There was recently an article on a RBP lift for the 09 F-150 inch Truckin' Magazine. It said it would work for 4x4 and 4x2 F-150's.
