Sponsored by: CARiD
Alignment question
Old Sep 12, 2009 | 07:15 PM
JackADF's Avatar
Alignment question
Hopefully someone can help me. First off I have a 2005 4x4 Supercab. I had the alignment done today and I noticed, after I got home, the driverside rear tire is almost completly under the wheel well. I have 35x12.50 17 on 17x8 wheels with 5in backspacing, and the other 3 tires are sticking out from the body at least 1 inch,which is normal, except for that rear dr side one. Is this a coincidence and I need to look somewhere else for a problem or would the alignment have caused this.
I also took the tire off looked around and nothing appeared to be bent, and measured from the frame to the inner tire on both sides and everything measures even. Any suggestions?
Old Sep 12, 2009 | 07:27 PM
the bed wasnt centered on the assembly line. There are no alignment adjustments in the rear. Just a coincidence.
Just FYI ive heard several complaints about this before on the 04-08 series trucks
Old Sep 12, 2009 | 07:39 PM
JackADF's Avatar
can i try loosening the bolts in the bed and shift it back or am i making it sound easier than it is. it must have happened recently because i just noticed today
Old Sep 12, 2009 | 08:22 PM
there isnt much adjustment in the bed from what ive seen, but it cant hurt anything, just mark on the bed where it was incase you want to move it back.
are you still under warranty?
Old Sep 12, 2009 | 08:36 PM
abervintageman4's Avatar
i dont think there is really any room for play in the bed as far as movin it side to side or back and forth.... if its under warantee i would definatley take it back to the stealership
Old Sep 12, 2009 | 08:51 PM
JackADF's Avatar
no its a 2005, warranty ran out a few years ago. another bone head thing i did the other day, that i forgot to include, was the jack bent while was rotating the tires and the truck slipped towards drivers side, it wasn't more that an inch or two off the ground when it happened, but maybe it was enough to push the axle towards the pass side??? luckly i hadn't removed the tires yet, just loosened the lugs. i completly forgot i did this. this opens up a whole new can of worms of possible problems.
Old Sep 12, 2009 | 08:53 PM
the axle shouldnt have moved unless that was installed wrong, if you think thats the problem, check your u-bolts to make sure they are tight and make sure you can still see the head of a bolt through your shims and the perch on the axle
Old Sep 12, 2009 | 09:12 PM
JackADF's Avatar
i hope its something simple like the bed, and not an axle problem. thanks guys for your advice. i should stop being so picky about it, i think i'm the only one who notices it.
Old Sep 12, 2009 | 09:21 PM
04-08 trucks have two alignment bolts in the leafs
but agreed
