Sponsored by: CARiD
What size block??
Old Aug 16, 2009 | 09:19 PM
RockTX's Avatar
What size block??
I have a leveled 04 2wd screw... Its time for new shocks and I want to add a block in the back for a little more height. Eventually, I would like to put 33X 12.5 all terrains on. I've decided on rancho quick lifts on the front and rancho rs9000xl on the back. How tall of block should I put in the back to achieve a level stance???(maybe a little rake) also, should I remove or keep the leveling kit(2.5")?? I'm thinking a 1.5 or 2 inch block.... thanks for any advice.
Old Aug 17, 2009 | 09:57 AM
mdhawkin's Avatar
If you put the quick lifts on you are going to want to remove the leveling kit. I think the 1.5 would be good, but just to be on the safe side I would measure the front vs the rear after you install the quicklifts. Also with leveling kit and nothing more you can run 33" on your 2wd.
