Sponsored by: CARiD
6" lift and leveling kit?
Old Aug 11, 2009 | 06:13 PM
Kansas_XLT's Avatar
well my trucks finally getting a fabtech 6incher put on thursday. The problem i have is i just invested a good amount of money to get it leveled a few months ago. I dont really want to just throw that money away so to speak. would it look ok with the 2" leveling kit on withe the 6"? Its the basic fabtech kit if that helps. Thanks for the help. I can hardly sleep at night and honestly the past few days every dream ive had has been about my truck
Old Aug 11, 2009 | 06:22 PM
RollTide09's Avatar
I left my 2.5" level on with my pro comp 6" suspension and it sits about an inch taller in the front than the back.
Old Aug 11, 2009 | 07:53 PM
HighOn22's's Avatar
I'm going to have to say that most of what you spent was probably on labor. If you pay someone to put on the 6" lift they more than likely won't charge you anything to take off the spacers if you want them off since the strut has to be removed anyway. You have the 2" spacer so you should be ok with leaving it if you do decide to go that route. I have the 6" procomp plus 2.5" spacer and will eventually take off and replace with Bilstein shocks up front.
Old Aug 11, 2009 | 10:27 PM
wandell's Avatar
Yes, you can install the spacer with the Fabtech. The question is whether or not you should. How big of a tire are you going with. If you want to fit 37's, by all means go with the leveling kit also. If you are only going with 35's, I'd leave it off.
Old Aug 11, 2009 | 10:53 PM
chazf150's Avatar
Go for it. I did mine , but added an extra 1.5" Lift in rr
Old Aug 12, 2009 | 01:32 PM
mhockey9090's Avatar
Leave it on gives you more clearance even if you stay with 35s. I did with mine and it looked great
