Sponsored by: CARiD
Need Help!!
Old Aug 4, 2009 | 01:57 PM
nlegler's Avatar
Need Help!!
OKay guys, got a 2.5" Hellbent leveling kit on its way. I just wanted to get some advice before putting my truck under surgery. Me and my buddy will be installing it just wondering if i could get some pointers to make the installation go a little bit smoother. Also could i get some torque specs for the different bolts and nuts i'll be taking off and putting back on. I dont want to leave anything undertightened and have something fall off!!. Thanks and i'll be sure to take lots of pics during the process! so lets here the wisdom come forth!!!!!
Old Aug 4, 2009 | 03:58 PM
ab46501's Avatar
There is a thread or two on here https://www.f150online.com/forums/ar...ll-photos.html and also https://www.f150online.com/forums/su...t-install.html. Having a buddy is the best thing you can do. I did mine myself in about 3 hours. 2 hours on the first side and 1 on the second. You kind of have to learn as you go but it is not real difficult.
Old Aug 4, 2009 | 04:51 PM
Jpaye's Avatar
Both of those write ups will help out tremendously, that is what I used and had no issues with the install. A buddy to help is always a plus
Old Aug 4, 2009 | 06:46 PM
mxracr's Avatar
I used those write ups as well. They are excellent! I would recommend the Pitman Arm Puller instead of the hammer and there is one large socket that the write up says you don't need a deep well. It is easier if you ignore that and use the deep well. Not a bad job at all if you use both of these (especially the pictures). I am a complete idiot of a mechanic and I was able to do it by myself.
Old Aug 7, 2009 | 03:12 AM
nlegler's Avatar
GUYS NEED HELP ASAP!!!! passenger side done perfect. okay driver side BIG ISSUE.. the upper ball joint will not tighten it only spins. i have tried prying down while trying to tighten it so it would catch and it wont and i cant think of anything to do will some one please help! im suppose to go in tmw to get new tires/rims/ and alignment done and this is the only thing stopping me!
Old Aug 7, 2009 | 10:34 AM
ab46501's Avatar
The bottom of the ball joint bolt has a hex head on it and you can put another wrench on it to keep it from spinning while you tighten the nut.
Old Aug 7, 2009 | 12:07 PM
nlegler's Avatar
If you guys could go to my profile and go to the help called hell bent install there are pictures of what my problem is and any adivice to get that fixed would be great... Its the only thing i have left to do and then it will be done!!
Old Aug 7, 2009 | 12:21 PM
ab46501's Avatar
Looks like you need to compress the spring some to help line things up and relax the tension on that bolt and nut. Either put a block under the bottom arm and lower it down or put a extra jack under the bottom arm and raise it up some. You should be able to put a wrench on the bottom of the bolt to hold it while you tighten the nut.
Old Aug 7, 2009 | 12:24 PM
ab46501's Avatar
The geometry of all that stuff can be really fickle. Sometimes changing the angle just a bit can make a big difference and it will all slip right in.
