Sponsored by: CARiD
leveling kit which one
Old Aug 2, 2009 | 09:10 PM
jjntj2003's Avatar
i have a 04 2wd f150 putting factory 4wd blocks on rear which front kit do i need 2" or 2.5" don't mind a little rake just don't want the bulldog look when pulling trailer or loaded.
Old Aug 2, 2009 | 09:29 PM
letsgosteelers8's Avatar
if you don't want any bulldog you should probably use the 2". with the block in the back you're still only going to be about as level as what you started with...since you are towing
Last edited by letsgosteelers8; Aug 3, 2009 at 12:54 PM. Reason: didn't read whole ?
Old Aug 2, 2009 | 11:57 PM
jdruzik's Avatar
I think it would be better to use an AAL instead of a block in back if you are towing...
