Sponsored by: CARiD
305/55r20's on 2wd ?
Old Jul 18, 2009 | 02:13 PM
Jeremysf150's Avatar
Ok, i'm about to buy new tires and i want to go with 305/55R20's on my factory wheels. I have an 06 2wd with an A.S. 2" leveling kit up front and I was told these tires would fit, is this correct?
Old Jul 18, 2009 | 03:22 PM
wandell's Avatar
They should fit using the OEM wheels. You may have to do some minor trimming.
Old Jul 18, 2009 | 11:41 PM
thanks man i'm gonna go with some nitto's...
Old Jul 19, 2009 | 09:13 PM
bewtew's Avatar
if you are sticking w/ the oem 20s, i doubt you'll need trimming. however, the tires will rub the upper control arm, and/or partially a small section of the front frame as well as the sway bar when you try a full lock when turning. i dunno how much of a difference it will be, but i'm running nitto grapplers 305/55/20 w/ bilstein 5100 set to 2" and that's what i experience. i've learned to max my turns to 1.25 revolutions only since i've noticed that past 1.5 revolution is when i rub. hope that helps.
Old Jul 24, 2009 | 09:13 PM
thats cool. my nitto's just came in today, but i'll have to wait till monday to get them put on. how does yours ride with them? anyway, thanks for the info...
