Sponsored by: CARiD
Has anyone tried 6" Pro comp with 37's?
Old Jul 16, 2009 | 11:38 PM
BLUEBEAST06FX4's Avatar
Has anyone tried to fit 37's on a 6" pro comp stage 1 lift and just do some trimming to make it fit? Or does anyone know if it will work?
Old Jul 17, 2009 | 09:10 AM
fx4 for life 79's Avatar
effonefiffty ran that set up for awhile
Old Jul 17, 2009 | 09:58 AM
IDNC76's Avatar
it depends on the specs of the wheel and a 37/12.5 would help aswell
Old Jul 17, 2009 | 12:44 PM
wandell's Avatar
I would add a little more lift by upgrading to the Pro Comp MX6 adjustable coilovers. Another less expensive option would be to replace your OEM coilover shocks with the OEM replacement Bilstien shocks. THese also feature adjustable spring preload to add up to 2 inches of lift.
Old Jul 17, 2009 | 04:25 PM
HighOn22's's Avatar
I'm running a Procomp 6" + 2.5" spacer. I have 37x12.5 Kumho's and there's no way they would fit with just a 6" lift. I had to trim when I 35's with just 6". I also have -25 offset wheel. Maybe with a higher offset they would work.
Old Jul 17, 2009 | 07:36 PM
WANDELL.... How much would those adustable coilovers cost?
Old Jul 17, 2009 | 07:53 PM
IORf150's Avatar
If i'm wrong correct me, but I am pretty sure they are about $1,000, somewhere around that area
Old Jul 17, 2009 | 10:21 PM
wandell's Avatar
Yeah, the MX6 coilovers are pretty high. The oem replacement Bilstiens would be a lot less expensive.
Old Jul 18, 2009 | 04:29 PM
do bilsteins, much cheaper than coil overs
Old Jul 18, 2009 | 11:15 PM
wandell's Avatar
And they would still be an upgrade from your OEM coilover shocks.
Old Jul 19, 2009 | 12:57 AM
ill definently have to look into it because i really want 37's
Old Jul 19, 2009 | 09:05 AM
southernboy06's Avatar
Agreed! I have this same set up except I am running 36x15.5 and i had to do minor trimming! Definately not going to happen with just a 6" lift.
Old Jul 19, 2009 | 05:44 PM
06yz250f's Avatar
what gears and motor do you have?
check fabtech, they had blem coilovers a while back for $560 for both.
the bilsteins ride great tho, i drove fx4 for lifes a few months back on a trail and it was smooth as hell compared to my stockers
Old Jul 19, 2009 | 09:35 PM
I have stock 3.73's with the 5.4 and an Edge tuner.
I may look into that, thank you.
Old Jul 19, 2009 | 09:47 PM
BAD DRVR's Avatar
My 37's are rubbing like crazy with an 8" lift. I'm just letting the tires "trim" away any extra plastic that is getting in the way. Fender flare, inner fender well, plastic running board. Going down the road and turning into a driveway or parking lot that has a bit of a hump is what causing me trouble
