Sponsored by: CARiD
problems with 2 in rear blocks and u bolts
Old Jul 10, 2009 | 01:44 AM
2wd98f150's Avatar
i have a 98 2wd f150. i put the rough country leveling springs on it. it sits higher in the front so i was putting 2 in blocks on. i bought cheaps ones at autozone because i'm a dumbass. i got custom u bolts made though.
when i got the blocks on and i looked under it looked like the spring had moved forward an inch or so on both sides. i know there is a nut that fits on the plate that the u bolts connect to but it seems to be pushed forward and i cant get them to connect. i don't really know how to explain it any better.
i need help FAST because i use my truck in my job and i want to know what i have to do asap.
thanks
Old Jul 10, 2009 | 10:07 AM
2wd98f150's Avatar
hey i really need help with this. if any one knows anything it would help
Old Jul 10, 2009 | 10:13 AM
mdhawkin's Avatar
Can you spin the blocks 180 degrees if they are offset that could help align them. Also, I have seen those blocks from Autozone, they very light weight, I would seriously look to upgrade now or the near future.
If rotating them will not help, take some pics and post so we can see your issue.
Old Jul 10, 2009 | 03:18 PM
2wd98f150's Avatar
where can i find better ones. i already have good longer u bolts
Old Jul 13, 2009 | 09:59 AM
mdhawkin's Avatar
Old Jul 16, 2009 | 01:11 PM
2wd98f150's Avatar
don't worry i got it. all i had to do was loosen both sides and then just pull the axle up to allign everything. this is the first time i've done it but i got it now and it is perfect thanks
