Sponsored by: CARiD
6in kit
Old Jul 8, 2009 | 07:14 PM
FordManBrad's Avatar
6in kit
I got a 02 f150. I am wanting to put it on 35x14.50x16 but It is hard to find a tire that size. What is the best 6 inch kit on the market for the price. The local shop is stuck on BDS Is there anything out there that is better or the same for a cheaper price. I am also wanting to do a 1 or 2 inch torsion bar lift and either a leaf or a box in the rear to get about 8inchs of lift. Just need some info thanks.
Old Jul 8, 2009 | 07:21 PM
l337viton's Avatar
Just a thought man, but i think you are going to need a bigger lift to fit 55 inch tires... unless that's a typo!
Old Jul 8, 2009 | 07:25 PM
Its a typo I mean 35x14.50x16
Old Jul 8, 2009 | 10:50 PM
wandell's Avatar
The 6 inch Fabtech or BDS would be great choices. You will have to crank up the torsion bars and do some trimming to fit a 14.50 inch wide 35.
Old Jul 9, 2009 | 07:36 PM
I talk to a guy at BDS and he said if I was to raise the torsion bars up with the lift it will wear out all kinds of stuff really fast is that true?
Old Jul 9, 2009 | 08:18 PM
4.2trimble's Avatar
depends on how much you crank them.
if you just crank them alittle you wont notice and difference in parts wearing.
but if you crank them all the way up you will notice some accelarated wear.
I ran my stock torsion bar adjustment keys all the way cranked for about 50k miles (which equalled 120k on the truck) before replacing my ball joints
Old Jul 10, 2009 | 12:15 AM
wandell's Avatar
I agree.
Also, I ran my torsion bars at stock height and had to replace my ball joints at 60,000 miles to give you a comparison to running them cranked up.
Old Jul 11, 2009 | 12:15 AM
blackbeast_FX4's Avatar
I am getting a 6 inch Skyjacker system with replacement rear springs and doing a 2 inch torsion key replacement with 2 inch blocks under the new springs and running 37 13.50s well thats my idea anyway im picking up the tires next week im on a 18x9 atx artillery rim as well any info the better
Old Jul 11, 2009 | 10:55 AM
wandell's Avatar
Stay away form the reindexed torsion bar adjustment keys. They will destroy your front end. They just allow you to put way, way too much preload on the torsion bars which destroys your ride quality and will create extreme CV and ball joint angles.
Old Jul 11, 2009 | 11:12 AM
well what do you suggest to get me up high enough to clear the 37s
Old Jul 11, 2009 | 11:11 PM
wandell's Avatar
Either crank up the torsion bars with the OEM keys and be careful on wheel choice or add a 3 inch Performance Accessories body lift.
Old Jul 12, 2009 | 01:54 AM
well that would work if i didnt have a full replacement with a winch kinda pointless to have that with a body lift ima just go with it and replace ball joints maybe i can buy in bulk haha might be cheaper
Old Jul 15, 2009 | 12:01 AM
Big_black04's Avatar
Old Jul 21, 2009 | 09:48 PM
I am gonna order the 6in bds kit and just run 35's for now what is a good offset and backspace for the rims. And I am btw the BF Goodrich a/t and the nitto grapplertires.
Old Jul 21, 2009 | 10:41 PM
wandell's Avatar
I'd suggest a 10 inch wide wheel with 4.5 inches of backspacing. This is a pretty common spec for 97-03 wheels.
