suspension lift question
Does everyone take off the leveling kit when adding a suspension lift? I'm considering a RC 6" lift but need to take consideration on the parking garage height. I have the 2 1/2 " level kit now and have only eight inches to sparebut if i remove the leveling kit I have 10 1/2" to spare. plus adding 35x12.5x18 mud grapplers. any help appreciated. height clearance is 7ft at the hospital. thanks
What size tires do you have now? If your running 33s, the tire height will only increase by about 3/4 of an inch and decline with time. Removing the leveling will probably give you a smoother ride because the of the reduction of coil compression.
