Sponsored by: CARiD
2wd to a 4X4 stance
Old Jun 28, 2009 | 09:52 PM
yama52's Avatar
2wd to a 4X4 stance
How do I make my two wheel drive stand like a stock 4X4 with a 2.5 inch leveling kit?
Old Jun 28, 2009 | 10:36 PM
wandell's Avatar
The stock 04-08 4x4's sit about 2 inches taller than the 4x2's. A 3 inch body lift and a 2 inch leveling kit will put you a hair taller than a stock 4x4 with a leveling kit.
Old Jun 29, 2009 | 10:57 AM
mdhawkin's Avatar
I would go with 2.5AS level and put 2'' blocks in the rear, that should get you very close to stock 4x4. Avoid the hassle of the body lift if possible.
Old Jun 29, 2009 | 08:03 PM
zackn's Avatar
What does AS stand for?
If you decide to go for the Daystar 2.5" coil spacer you will have to get longer control arms and longer shocks. You can get a Daystar 2" coil spacer though and you'll be in the clear.
http://www.4wheelparts.com/Lift-Kits...9333&t_pl=7140
Old Jun 29, 2009 | 08:29 PM
thejake1989's Avatar
AS stand for Auto Spring
Old Jun 29, 2009 | 08:49 PM
zackn's Avatar
Auto spring?
yama52's Avatar
I was under the impression the 2.5 inch level kit for the front did not requier anything else but then to bolt it on. Is there a lift kit that I can buy that would be equal to what a a 4X4 is without having to do the leveling kit or body lift? In other words a full kit like fabtech, but not a 6 inch lift.
Old Jun 29, 2009 | 08:52 PM
Auto Spring is a brand of leveling kit google it
Old Jun 29, 2009 | 10:57 PM
wandell's Avatar
I believe all of the suspension lifts for the 4x2's are 6 inches. That would put your 4x2 at the same height as a 4x4 with a 4 inch suspension lift.
Old Jun 30, 2009 | 07:56 PM
shocker11's Avatar
1" rear block
2.5" front auto spring spacer
3" body lift
I am going to be running this set up as soon as i get the body lift in
Old Jul 2, 2009 | 12:12 AM
yama52's Avatar
Originally Posted by shocker11
1" rear block
3" body lift
I would love to see some pic's after you get the job done.
