Sponsored by: CARiD
ttb front end wheel hopping
Old Jun 14, 2009 | 09:06 PM
bigblue24's Avatar
I have a 1990 f150 and the front end just started hoppin really bad. I have 35in ground hawgs and its never done this before with them. Im not really sure what is causing it any ideas would be much appreciated
Old Jun 14, 2009 | 10:09 PM
che22879's Avatar
It could be bad ball joints, radius arm bushings or ttb bushings. have you balanced the tires? hope it helps.
Old Jun 14, 2009 | 10:20 PM
bassntruck's Avatar
gone muddin' lately? Mud in the rims made mine hop pretty bad around 60mph
Old Jun 15, 2009 | 08:59 PM
bigblue24's Avatar
yea the tires are balanced and the way the are hopping is defintely not a balancing problem but thanks for the help and rims are clean. Would the shocks or springs cause any problems if they were bad?
Old Jun 15, 2009 | 09:36 PM
che22879's Avatar
no, its most likely ball joints or bushings.
Old Oct 17, 2011 | 05:53 PM
mudbogger93's Avatar
this happened to me and i replaced ball joints, radius arm bushings, wheel bearings, and front hubs and its still doing it so the only other thing would be maybe u joints or the ttb bushings if i figure this out ill let you know and if you figure it out let me know..
