Sponsored by: CARiD
Super Lift super runner steering kit
Old Jun 5, 2009 | 05:26 PM
aswaff400's Avatar
i was wondering if anyone has ever used this (or similar) on their truck? my ball-joints are worn badly and giving me the death wobble and i want to upgrade to something that can handle abuse from the larger tires off road better than the OE setup
http://broncograveyard.com/bronco/i-...r_steering.htm
Old Jun 8, 2009 | 01:03 AM
Nemisus's Avatar
Not too familar with the full size TTB, but I'm assuming it works the same as what came in the bronco II's and Rangers!
If your planning on keeping the TTB.. than I'd recommend getting the SRS, as it made the world of differance in my 87 Bronco II! Although mine was lifted and I needed something different than stock!
I later modified my SRS to work with over 8" of lift! Solid set up and if I were to ever have another Ford with TTB, I'd definately get another!
Good luck
Here is a picture of my 87 Bronco II before I went Solid axle! You can see how the modified SRS works quit well:
Cheers
Nem
Old Jun 8, 2009 | 01:56 AM
ATOM1's Avatar
i buddy had the superrunner on an older ford and he said there wasn't worth the money. this will do nothing to help out your ball joints, ford bj's suck on ttb trucks, i used to replace my ranger bj's every spring and i was lifted 4 inches and running on 31's
