Sponsored by: CARiD
Want to go higher!
Old May 25, 2009 | 08:39 PM
rjay's Avatar
Want to go higher!
I've got an 02 Screw 4wd with RCD suspension lift (been told 5" and 5.5" lift) not sure which one, with 33" tires. Still in the process of getting new wheels and tires (which will be 18x9 wheels and 35" tires), but can I add on to the lift I already have? Such as spacer/leveling kit for the front and bigger block for the back? I really just want a couple of more inches. Thanks
Old May 25, 2009 | 09:45 PM
4.2trimble's Avatar
3" Performance Accessories body lift will give you a nice amount of lift. and enough room for at least 37's
The PA body lifts are priced good and comes with everything you need, but you can buy gap gaurds to hide the gaps.
I have one on my 99 great product.
Old May 25, 2009 | 10:26 PM
wandell's Avatar
You can crank up your torsion bars for a little more lift. I'd do that if you only want 35's. I wouldn't add a body lift unless you are gonna go to at least 37x12.50's.
Old May 25, 2009 | 11:27 PM
rjay's Avatar
Definitely don't want a body lift. I can fit 35's with the setup I got now. I was just wondering if I could add a leveling kit in the front and maybe bigger blocks or something in the back that would raise it an additional two inches or so.
