Sponsored by: CARiD
Rear End Shim on Pro Comp???
Old May 25, 2009 | 05:50 PM
HighOn22's's Avatar
Is there any reason why Pro Comp's 6" lift does not come with a shim for your rearend? My pinion seal went out on my truck due to the angle of my shaft. Warranty will not cover this.
Old May 25, 2009 | 06:24 PM
tlt008's Avatar
Don't you have your truck bumped up to 8"? From what I understand none of the 6" its supply a shim because they aren't really needed. It's only when you get up to 8"+ that you're angles get bad. I could be wrong thugh. I know I need to either extend my driveshaft or get a shim because mine is out a good 2" or so and i have a vibration when I let off the gas at highway speeds.
Old May 25, 2009 | 09:02 PM
HighOn22's's Avatar
The front is bumped up to 8". The rear is only 5" higher than factory. If I took the spacer out up front my truck would sit level. There are a few people who have the Procomp with the 5.5" block in the rear. Do ya'll have a shim also or just the 5.5" block?
