Ideas For My Lift
Ideas For My Lift
So i just got my 04 lariat 4x4 want to get at least 35's on it. i saw a nice *** truck on here that had a 3" leveling kit and an inch and 1/2 add a leaf on 285/65/20 witch seamed perfect. the combo would only be about 350 for the lift. But not sure if i should get get a 6" suspension. Any Ideas or comments?
It all depends on what you want. If you want a big truck then you need the 6" suspension. If you want something leveled out with an nice stance thats not too big then go with the level.
If you are having doubts that the leveling kit will not be big enough then go ahead and get the 6". You will be dissapointed if you dont.
dont do a 3" kit, its to much stress on your front end.
you can do a 2 1/2 max if you decide on a leveling kit and still can fit 35's on stock wheels. the 4" rancho is another option, its a little more than a 6" but you can use stock wheels. i have a 6" and love it, gonna bump it to 7" when i replace the struts
they are right if you don't get the lift you want the first time you will spend more trying to make yourself happy so take some time think it Though thin run with it and good luck and post lots of pic!
If you want to try a three inch level kit then you could by mine for cheap and then later you could regret it like I did. I'm going with the rize now
