Sponsored by: CARiD
can i add a 2" spacer to pro comp
Old May 15, 2009 | 12:53 AM
clifford2004's Avatar
i had a 6"pro comp stage 1 i got rid of the front spacer for the bilstiens do you think i could add a 2" spacer ontop of them for 8" of lift and go with the 5 inch procomp block in the rear?
Old May 15, 2009 | 01:56 AM
06yz250f's Avatar
if you dont have the pro comp spacer any more then yes you can put a 2" spacer, do not double stack spacers tho
Old May 15, 2009 | 12:26 PM
ya i took out the pro comp 6" spacer and put in the longer bilstiens
Old May 15, 2009 | 09:27 PM
fx4tough07's Avatar
Are the bilsteins adjustable, if so then crank em
Old May 15, 2009 | 10:51 PM
wandell's Avatar
I agree. If they are not, add a leveling kit.
Old May 16, 2009 | 10:02 AM
the only adjusment was when you put them together you can set the spring perch at 4 or 6" of lift
Old May 16, 2009 | 11:01 AM
Lifted_f150's Avatar
hows the ride compared to the 6" spacer? I have the spacer and i'm looking to do the same thing you are.
Old May 17, 2009 | 11:23 PM
its alot nicer, money well spent you pick up some more travel too, put up a pic of your truck i wana switch to the black Nfab step bars
