Sponsored by: CARiD
Fabtech Done pic !
Old Apr 26, 2009 | 01:07 AM
JWBFX4's Avatar
Looks great
Old Apr 26, 2009 | 11:38 AM
4x4wolf's Avatar
Very sweet
Old Apr 26, 2009 | 11:55 AM
2005_SilverF150's Avatar
Looks pretty good, but like everybody else said, alignment is gonna be needed
Old Apr 26, 2009 | 12:15 PM
87fiveoh254's Avatar
Holy negative camber, Batman!
Looks good.
Old Apr 26, 2009 | 10:37 PM
jrohrigj's Avatar
looks good
Old Apr 28, 2009 | 11:53 PM
hawaiian boy's Avatar
Brah! looks good, BUTT align that motha!!
Old Apr 29, 2009 | 01:20 AM
Da Show's Avatar
Looks awesome, I really like those tires. I thought hard about getting the MTZ's but I ended up going with the Toyos.
Old Apr 4, 2010 | 09:22 PM
w3tw1lly's Avatar
little update...
now i want to mount it on 37/12.50/R17 so what a need more?
i just need fabtech dirt logic coilovers 2.5 ?
thx
Old Apr 4, 2010 | 09:27 PM
GatorBoi's Avatar
niiiiice
Old Apr 4, 2010 | 11:44 PM
got556's Avatar
To mount 37's I would get the DL's and crank'em up two inches, and then get a 6" block w/ a 1.5" AAL or get a 4" leaf pack and 3 or 4" block. Basically you're gonna need 7.5 to 8" of lift to get the 37's to look right and fit right. You're also gonna need to re-gear at that point to 4.56's or 4.88's and may have to put a driveshaft spacer on or get a new driveshaft....
Good luck and can't wait to see where this truck finally ends up once you're done modding. I know I can't wait to get my Fabtech on.
Old Apr 5, 2010 | 12:33 PM
w3tw1lly's Avatar
nice info man thx
Old Apr 5, 2010 | 12:43 PM
fx4 for life 79's Avatar
yeah grab some dirt logic and crank those a couple inches and a 2" add a leaf. and u would need to reagear.
fabtech already uses a driveshaft spacer if im not mistaken
Old Apr 5, 2010 | 05:24 PM
w3tw1lly's Avatar
and with my Fabtech when I put it on the 4x4 it does A LOT of vibration is normal?
and when its on 2x4 it does no vibration...
Old Apr 5, 2010 | 09:38 PM
305f150's Avatar
You can add a BL and not worry about the drive line
Old Apr 5, 2010 | 09:57 PM
mSaLL150's Avatar
You need to re-clock the front driveshaft. The master key must be grinded down, and the slipyokes aligned. This will fix your vibration and will prevent pre-mature failure of the front driveshaft. If you still have a slight vibration or use 4x4 at highway speeds, you may have to also have it re-balanced at a driveline shop. Mine didn't need to be re-balanced, not all do.
Looks great. I love haw the Fabtech sits perfectly level out of the box with no spacers, no stacked blocks/shims, and new shocks on all 4 corners.
