Sponsored by: CARiD
upper control arm replacement
Old Apr 15, 2009 | 11:44 PM
munoxide's Avatar
So i was at the tire shop today getting new rubber and alignment and they came back at me with a $425 for replacing 1 upper control arm and idler arm parts and labor I dont think so......My question is, before i break the nut off the ball joint, i know its under pressure....so should i jack the wheel off the ground to release the spring tension or should i jack it up underneath the lower control arm to tension the spring to take off the ball joint nut? 2001 4x2 f150 5.4 scab.......
Old Apr 16, 2009 | 12:59 PM
chiefFX4's Avatar
the thing won't come flying out if you just take the nut off.
get the tires off the ground, pull the castle nut and then hit up on the upper control arm. everything comes apart safely.
they didn't say anything about the lower ball joints?
Old Apr 17, 2009 | 11:35 AM
munoxide's Avatar
no, why?
Old Apr 17, 2009 | 12:01 PM
1BAF150's Avatar
damn, that sucks big time...you can def buy the upper a arm yourself and do the install...and not spend near that!!! Haha, knock on wood because Im sitting in the waiting room while my truck get a nice tire balance! Haha, these guys hate me bc I have baja claws...
Old Apr 17, 2009 | 12:53 PM
1fast4.6's Avatar
i spent 250 on 2 brand new upper control arms... Hope they gave you some vasiline
Old Apr 18, 2009 | 10:18 PM
munoxide's Avatar
Gave me some? I GAVE them a big F-you!
Old May 16, 2009 | 09:24 AM
TX150XLT's Avatar
I spent less than 120.00 for 2 upper control arms!! only 7.00 for shipping. Now just gotta put them on....
Old May 16, 2009 | 04:24 PM
Swackly's Avatar
Not bad to install but need to get front alignment after
Old May 20, 2009 | 02:56 PM
uppers are really easy, just need to do an alignment after all is said and done. Idler arm is pretty easy if you get the puller and the large socket needed.
