Sponsored by: CARiD
Going Under the Knife!
Old Mar 7, 2011 | 12:34 AM
  #601
1fast4.6's Avatar
Well worked on her all weekend but haven't gotten to fire it up. Not too far away! Found out the hard way my airtanks were mounted to high. Was hitting the cab, so had to lower them. Then it was an onslaught of wiring and brakelines. AC is hooked up, tranny coolant lines, and many other things. But it's back to work in the morning. The list is getting smaller!!
Old Mar 7, 2011 | 12:40 AM
  #602
1fast4.6's Avatar
I might be willing to make you a deal if you wanna toss some boost at 'er
Sounds like a good offer but my funds are tied up! Damn economy
Old Mar 7, 2011 | 06:00 PM
  #603
1fast4.6's Avatar
This is where the air tank was hitting the cab
And the air tank.. I didnt have to drop it but maybe 1/4 of an inch.
Old Mar 8, 2011 | 10:27 PM
  #604
1fast4.6's Avatar
Well gentlemen... i need some serious help.. She cranks but no fuel. Checked all the way up to the connection on the drivers front fender.. No juice. But there is juce at the main fusebox. HELP!
Where is pat when you need him
Old Mar 8, 2011 | 10:48 PM
  #605
bmxrider5x's Avatar
well if u got power at the fuse block im assuming leaving the fuse to then check relay fuel interia switch how ever u spell it if those two are ok then trace ur wire till u find a open
Old Mar 9, 2011 | 02:01 PM
  #606
1fast4.6's Avatar
Yes! got my fuel pump to work. Primed the system.. aaaannnnnndddddddd nothing.. wont hit. Ive got power to my coils and injectors.. humm.. odd
Old Mar 9, 2011 | 02:12 PM
  #607
bmxrider5x's Avatar
ok next easiest things to check see if ur crank sensor hooked up along with cam sensors if they are plugged up check power and ground u know
  #608
flamed20's Avatar
been there before with my brother's truck....double check all your grounds..
Old Mar 9, 2011 | 09:11 PM
  #609
1fast4.6's Avatar
Argh.. this is really starting to deter me.. Ive checked everything i can. All grounds are good.. plenty of fuel pressure.. Coils accually have juice going to them.. Im clueless.
Old Mar 9, 2011 | 10:08 PM
  #610
IIRC coils/injectors are grounded by the PCM
Old Mar 10, 2011 | 08:20 PM
  #611
1fast4.6's Avatar
Well i found another ground wire! but it wasnt the trick It just grounded the motor to the frame.
If its grounded by the PCM.. ive attached and checked every ground wire that comes out of it. Im clueless
Old Mar 15, 2011 | 04:36 PM
  #612
1fast4.6's Avatar
New update.. It appears that i got way ahead of myself. It seems that i still have a fuel problem. I have spark. and 45 psi fuel pressure with the key on.. 35 while cranking.. Next step is to check the injectors. I did get it to run with starting fluid.. Yes yes i know.. bad.
Isnt troubleshooting fun kids?
Old Mar 16, 2011 | 07:53 PM
  #613
1fast4.6's Avatar
YAHOOO almost there!
<object width="400" height="224" ><param name="allowfullscreen" value="true" /><param name="movie" value="http://www.facebook.com/v/999325396890" /><embed src="http://www.facebook.com/v/999325396890" type="application/x-shockwave-flash" allowfullscreen="true" width="400" height="224"></embed></object>
Would have ran it longer.. but seeing that there is no water in it.. not a good idea.
Shes probably just on 4 cylinders.. pulled the vacume to the regulator and it probably just got some air in the system!
AND WOW ITS LOUD... probably going to have to change that
Old Mar 16, 2011 | 08:09 PM
  #614
It's alive! Keep plugging away, man.
Old Mar 16, 2011 | 08:15 PM
  #615
06lariat4x4's Avatar
sounds like improvement
