Sponsored by: CARiD
Difference between shackle drop and block removal?
Old Apr 4, 2009 | 08:52 AM
ZEEKA's Avatar
I see a lot of post about guys putting 2" lowering shackles on the rear of their trucks to lower/level out the rear end. I removed my 2" rear blocks (its a 4X4) to gain the same effect. Is there really a difference between the two?
Old Apr 4, 2009 | 12:18 PM
I have no idea why you would put a drop shackle on before removing the blocks. Looks as if they would just offset each other. I think you did the right thing by removing the blocks.
Old Apr 4, 2009 | 12:26 PM
wandell's Avatar
Right. Why buy leveling shackles when you can remove the blocks for free? Maybe do both and install some lowering springs up front for a 2/4 drop.
Old Apr 4, 2009 | 07:25 PM
ZEEKA's Avatar
Ok good, thats what I thought. I'm not sure how much a shackle costs but I know it cost me about $20 for shorter U-bolts and about a half hour of my time to lower mine. Maybe its the 2wd guys that are using the shackles because they have smaller rear blocks (1").
Old Apr 4, 2009 | 08:45 PM
alomar's Avatar
It depends on the vehicle. If it comes with a block, you remove the block to level it. But my truck did not have a block therefore I needed a shackle. Just all depends on the vehicle. Some 2WD's have a block, some dont. Different jobs for different applications.
Old Apr 4, 2009 | 08:50 PM
Really the only difference between the two is the lowering shackles lower your towing capacity due to the leaf angle change.
