Sponsored by: CARiD
38's on a 2wd
Old Feb 19, 2009 | 01:43 AM
thorherc67's Avatar
38's on a 2wd
Hey i have a 2wd 06 and as of right now i have 36's and i can clear them just fine. i cranked the DL coils that i have so i can clear 37's and i was curious if i could throw some 38x13.50r20's? If i have the room for 37's i assume i could trim what is needed and do some 38's. What do you guys think?
Also i realize i will need gears, what do you recommend? i don't know a thing about gears
Old Feb 19, 2009 | 01:49 AM
Fifty150's Avatar
Why would you want to? What is the purpose of that extra inch?
Old Feb 19, 2009 | 01:50 AM
thorherc67's Avatar
i don't know.. i guess the extra inch haha
ps i just realized i put this in the wrong section.. sorry!!
Old Feb 19, 2009 | 08:26 AM
IDNC76's Avatar
not sure but i ve checked out the specs on toyo mt's before
and a 37/13.5R20 is 37.1
.........38/13.5R20 is 37.7
not much difference
Old Feb 19, 2009 | 10:49 AM
Eff One Fifty's Avatar
do it.
Old Feb 19, 2009 | 11:09 AM
minimonster17's Avatar
4.88 is recommended ratio for 36's+, but you have a 2WD, so you could go even lower, to a 5.13 or so.
Old Feb 19, 2009 | 11:27 PM
f150monster232's Avatar
I hate stupid people, thats going to be a tight fit because 2 wheel drives site 2 in. lower than 4 wheel drives.
And for all the people that don't know this most 37s are 12.5-13.5in. WIDE
Most 38s are 15.5in wide and give the truck a much more beefy look. i would check your rims and see but i dont see how you going to fit 38 on a 2 wheel drive that only has a 6in lift with 2in spacer. you might need to look at getting a body lift. hope this helps
Old Feb 20, 2009 | 11:57 AM
wandell's Avatar
I think you would need at least a 6 inch lift, a leveling kit or cranked up coilovers and a body lift to fit 38's on a 4x2.
Old Feb 20, 2009 | 02:26 PM
thorherc67's Avatar
how am i stupid??
The 38's i am looking at are 14.30 wide, look at the toyo website..
and i have a 2.5 inch spacer with my coils cranked, and no my UCA angle is not bad at all which is surprising. The rims i have are 10 inches wide and have a 5 inch backspacing.
Old Feb 21, 2009 | 01:54 AM
rafnaderfx2's Avatar
so if i get coilovers i can fit 37" tires?
i have a 2wd with a cst 7" lift.
Old Feb 21, 2009 | 08:19 AM
wandell's Avatar
A lot depends on the wheels you use and the width of the tires. Your Pro Comp wheels have decent backspacing and are not overly wide so you may be able to run 37's with a little more lift.
Old Feb 21, 2009 | 03:30 PM
06yz250f's Avatar
Originally Posted by thorherc67
how am i stupid??
so you basically have about a 3.5-4" spacer (2 1/2 spacer, 1" or so coilovers) ?? if thats what you have you have MAYBE 10" of lift max, you maybe could fit them, but the best way would be get a BL to make sure before you dump all that money on the tires
if you cranked coilovers youd get 9-9 1/2" of lift. not sure how much exactly you can crank on them but i bet you could get away with 37/13.50's with minor trimming
Old Feb 24, 2009 | 01:10 AM
thorherc67's Avatar
so with maybe 10 inches of lift on a 2wd would that be about maybe 8 inches on a 4wd?? So can you fit 38's on a 8 inch lifted 4wd truck? i parked next to an f150 with a basic 6 inch procomp lift 4wd and mine was about 2 inches taller than his. what does that mean??
Old Feb 24, 2009 | 02:08 AM
Hash278's Avatar
It means that technically you have 4" more lift than he does but you only sit 2" higher because his 4x4 comes higher from the factory. So yeah to clear 38's I would say you would need a BL lift
Old Feb 24, 2009 | 06:09 AM
stealthsniper96's Avatar
Get a body lift
