About to RIZE it up
i just went out side and looked at the with a tape. i think they ar 20x10's if so they have a 5.03 backspace. they have 305 55 20 nittos on them and they stick out about a inch to a inch and a half out passed the fender flair.
Then yeah I would agree that they are the 20x10's. I think they just look they don't stick out much because they don't have a high sidewall tire that bows out much. You should be good I'm guessing.
i can't tell or give you a definite answer, but if they make a 20x9 and 20x10 i would definitely start measuring very carefully so your truck doesn't go out of commission for a few weeks waiting on wheels. you could also call the PO if you didn't buy from a dealership
I agree with him. I have 8.5"'s of lift and running 37's. 38's would fit with ease. At my closest point of rubbing I have 1 1/2" before it hits. I'm also running this with a wheel that has a -25 offset (stick out 3"s)
You can find a set of spacers on Ebay for less than $150. It's not a great idea for a long term fix in my opinion but would get you by until you get up enough $ to get replacements. I'd go ahead an order the spacers for now and try to sell your wheels while saving for new ones. That's just me though. Atleast you figured this out before you destroyed your rims!
http://www.ezaccessory.com/Wheel_Ada.../6135-6135.htm
this is what i have on the way
how stupid would it look with 20x10's on the front for now . just buy 2 rims hahahah. then get the other 2 later ahahahha
Those look exactly like the ones I found on ebay for like $63/pair.
In all honesty.....I think just doing the 20x10's on the front would look like dog ****! The front wheels stick out further then the rear do already so to increase that would be retarded. Your truck though bro so don't let anybody sway you from what you want to do to it!
Good thinking and good luck with the sale. What are you gonna get to replace them? I'd try to find a 20x10 set just in case you want to go with a wider wheel later on like a 15.5. Again, 4.5" bs is optimal.
