Sponsored by: CARiD
need some help please!
Old Feb 13, 2009 | 03:39 PM
d4life45's Avatar
Question need some help please!
well today i was suppose to get installed a 1.5 inch spacer in the front and a 1.5 inch AAL in the back. i got the 1.5 inch AAL in the back, but the spacer they didnt install kuz it would cause wear on my tires. now the back sits a little higher. what can i do to level it out? should i order a 1 inch spacer or just take the AAL off? i have a 7.5 inch fabtech and 3 inch PA body lift already. what suggestions do you have? thanks for the help.
Old Feb 13, 2009 | 03:56 PM
d4life45's Avatar
and the spacer would cause the tires to tilt inward. would the 1 inch spacer cause it to do that?
Old Feb 13, 2009 | 05:46 PM
You need an alignment after adding a coil spacer. I did, no problem.
Sounds like the install shop you took your truck to doesn't know what the heck they are talking about. There is a ton of members here who have coil spacer lifts.
Old Feb 13, 2009 | 06:04 PM
d4life45's Avatar
after adding the AAL the back sits one inch higher then the front, so would the 1 inch coil spring spacer get it back to level?
Old Feb 13, 2009 | 07:18 PM
d4life45's Avatar
anyone else?
Old Feb 13, 2009 | 08:14 PM
wandell's Avatar
I agree. Find another shop to install the spacers and align the front end and you should be close to level.
Old Feb 13, 2009 | 11:18 PM
d4life45's Avatar
so with that 1 inch spacer i should be close to level since the back is 1 inch higher then the front?
Old Feb 13, 2009 | 11:24 PM
If your math is correct, yes.
Old Feb 14, 2009 | 02:17 AM
d4life45's Avatar
cool well thank you all for your help! if anyone has anymore suggestions or ideas about my situation let me know.
