Sponsored by: CARiD
How do i tell if torsion bars has been cranked?
Old Feb 8, 2009 | 05:25 PM
Txmj83's Avatar
Question How do i tell if torsion bars has been cranked?
How do i tell if the pervious owner has cranked the torsion bars up all the way?The ride has always been a buck board. I have had the aliment done three times scene i have owned the truck and ever time it had been dead on.
Old Feb 8, 2009 | 05:30 PM
4.2trimble's Avatar
lFind the torsion keys, theres a bolt in them if its tightened up then they have been messed with.
Just follow the Torsion bars back till they end into a crossmember. Then the Torsion keys are in there and the bolt head will be facing down.
Old Feb 8, 2009 | 05:52 PM
Txmj83's Avatar
Ok i followed the bar back. i fount the bolt head facing down. There is about half of the bolt on either side of the key. Dose that mean it has been cranked?
Old Feb 8, 2009 | 05:57 PM
4.2trimble's Avatar
i doubt they are... but its hard to say exactly.
Old Feb 8, 2009 | 06:02 PM
Txmj83's Avatar
OK well thank you for your help. I guess that year modle was just a rought ride.
Old Feb 8, 2009 | 06:06 PM
4.2trimble's Avatar
id change the shocks.
what load range are your tires? That will durastically change ride quality.
Old Feb 8, 2009 | 06:31 PM
wandell's Avatar
If you have around 1/2 inch or more thread showing on the adjustment bolts they are not cranked up much if any.
Old Feb 8, 2009 | 06:33 PM
dhugo2's Avatar
You could just go ahead and crank them down a little to see if it helps. Your front end will drop slightly though.
Old Feb 8, 2009 | 07:07 PM
Txmj83's Avatar
new shocks "Gabriel" and a new set of 4ply tires (bridgestone-revo)
I might go a head and crank them down a little to see if it helps.
Will any of this mess up my aliment?
Old Feb 8, 2009 | 07:13 PM
4wd150's Avatar
whenver you turn them you need an alignment
Old Feb 8, 2009 | 08:36 PM
Txmj83's Avatar
I could measures the threads crank it down if it dose not help put it back at the same measurement and all will be good right?
Old Feb 8, 2009 | 10:46 PM
wandell's Avatar
I'd carefully count the number of turns instead.
Old Feb 9, 2009 | 09:33 PM
Texashunter1977's Avatar
The threads will be different on each side. I cranked mine on my 2001 4wd supercrew, but before I did, I counted 11 threads exposed on driver's side and 8 on passenger's side. I'm sure it's different for every truck, but if yours are close to that you probably have something else going on. I would check shocks and tires for the stiff ride.
Nick
Old Feb 9, 2009 | 09:39 PM
Wandell, I have a very similar truck as you. I installed a 4" pro-comp lift and 315/70/r17 maxxis mudders. Recently, when I go over small bumps in the road, the front driver's side tends to bounce too much....sometimes it goes into a full-shake that will chatter your teeth. It doesn't pull and drives perfect most of the time, but every now and then it goes completely crazy! I have to let off and slow down for it to stop shaking, then I can get back to normal. Since you've been on here and had so many posts, have you heard of this?
Also, how do you include pictures on posts?
I would appreciate any help I can get.
Thanks,
Nick
Old Feb 9, 2009 | 10:03 PM
Txmj83's Avatar
Those are all good question. For the truck question my truck is stock my fornt diver side will knock when i go over bumps. it sounds like something is really wrong. i have checked it severl time and the dealer and may other mecahices nobody can come up with a promblem. I have drove it like this for the past 5 year nothing has fallen off yet so i just forget about it.
As for the pictures i don't know i have been trying to get this my self. When you get that info let me know
